Building solid body, need help
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=13308
Author:  bmg6690 [ Mon Aug 20, 2007 3:54 pm ]
First I would like to say hello, as I am a new member.  Second, I am building a solidbody electric guitar and have some questions (this will be the first guitar I make).  I am planning to build a guitar with a double cutaway les paul body style.  I plan to install a standard american strat tremelo system, one modern classic gibson humbucker, and one gibson p90 single coil pickup.  That is the main part.  I was wondering if it is best to go ahead and order everything now so i can measure it up, or would it be okay to order as I go.  The main thing that brought this up to me was that I do not know the exact measurments of the gear I want to install so I'm not sure if I need it to begin.  Please give your suggestions or thoughts and ideas or questions for this guitar.  I would really appreciate some help.
Author:  Brock Poling [ Mon Aug 20, 2007 3:57 pm ]
[QUOTE=bmg6690]
<FONT face="Times New Roman, Times, serif" size=3>First I would like to say hello, as I am a new member.  Second, I am building a solidbody electric guitar and have some questions (this will be the first guitar I make).  I am planning to build a guitar with a double cutaway les paul body style.  I plan to install a standard american strat tremelo system, one modern classic gibson humbucker, and one gibson p90 single coil pickup.  That is the main part.  I was wondering if it is best to go ahead and order everything now so i can measure it up, or would it be okay to order as I go.  The main thing that brought this up to me was that I do not know the exact measurments of the gear I want to install so I'm not sure if I need it to begin.  Please give your suggestions or thoughts and ideas or questions for this guitar.  I would really appreciate some help.
The first thing I would do is draw a detailed plan. That should make everything clearer.
Arched or flat top?
Author:  Mattia Valente [ Mon Aug 20, 2007 4:18 pm ]
The way to do this:
1) order your hardware (all the important stuff - bridge, tuning machines)
2) draw a full-sized plan, front and side views. The level of detail is up to you. Accurate neck position, angles, hardware location are essential.
3) start building.
Author:  bmg6690 [ Tue Aug 21, 2007 9:40 am ]
I am planning on making a flat top.  For drawing the plans out, is there a way to determine things like the size of the pickup pockets with out measuring the actual pickups?  Like is there a universal pocket size for this or do they need to be carefully measured before planning the pocket.  Do you think the humbucker and p90 sounds okay or will one drown out the other or anything like that?
Author:  Brock Poling [ Tue Aug 21, 2007 12:52 pm ]
There are templates for p90s and humbuckers around. Google for them. I would be surprised if you can't find a PDF doc with them in it, if you can't find them let me know and I will scan some for you.
Author:  bmg6690 [ Tue Aug 21, 2007 1:49 pm ]
I cant quite find one.  The closest i can find is over priced templates for sale on some websites.  That would be great if you could scan them, or maybe if you could just find me a link.  Either way I would really appreciate it.
Author:  old man [ Tue Aug 21, 2007 1:57 pm ]
Humbucker specs.
Author:  bmg6690 [ Tue Aug 21, 2007 2:05 pm ]
Author:  old man [ Tue Aug 21, 2007 2:08 pm ]
Also, I believe the Melvyn Hiscock book has the drawing for the P90 cutout.
Author:  Rick Turner [ Tue Aug 21, 2007 2:14 pm ]
Those "overpriced templates" aren't so overpriced when you consider your time and the precision with which they are made. I hardly ever build jigs that I can buy these days. Stew Mac's pickup templates are very reasonable for what they are, I think.
Author:  bmg6690 [ Tue Aug 21, 2007 2:28 pm ]
I am really new to this, I guess once I keep getting into this and go furthur into the project I will realize it is reasonable.  I guess at first look they seemed a little pricey
Author:  John Lewis [ Tue Aug 21, 2007 2:51 pm ]
Pickup templates from stewmac - what Rick said; buy these for $11.00 + shipping and go to it.
Good luck-
Author:  Mattia Valente [ Tue Aug 21, 2007 5:56 pm ]
The templates are cheap, and I'm lazy.
This said, go ahead and get the Hiscock book. Making a P-90 template requires a few bits of straight scrap, a router, a square, and a drill bit for the corners. And I'd reccomend measuring the actual pickups, because the routes may not be as 'tight' as you prefer them (I've never had issues, but I've seen people complain before.)
Author:  bmg6690 [ Wed Aug 22, 2007 9:35 am ]
Does this template for a strat tremelo system have the template for both screws and the posts if you flip it?  I cant really tell.
http://www.stewmac.com/shop/Tools/Special_tools_for:_Routing /1/Tremolo_Routing_Templates/Pictures.html#details
Author:  Setch [ Wed Aug 22, 2007 8:43 pm ]
The Hiscock book also contains a strat tremolo template, which can be used to make your own router templates.  I highly recommend buying the book, not just for the templates, but for the overview of construction it'll give you.
The web, and forums like this, PG and the MIMF are great, but for a comprehensive overview, 'Make your Own Electric Guitar' is tough to beat.
